LH2Y NFFler
Anmeldungsdatum: 23.09.2024 Beiträge: 23
Verfasst am: So Okt 13, 2024 6:49 am Titel: Ready for DLR? |
My test is in 9 days and I'm wondering if I am ready, here are my results for the past 3 runs.
Example: Oldest to newest (70%, 80%, 90%), 90% is the newest result and 70% is the oldest.
PPT: 100% in 11min 41 sec, 100% in 12 min 51 sec, 95% in 13 min 19 sec
SKT: 91%/84 item, 88%/ 86 item, 90%/81.9 item
WFG: 100% in 3 min 52 seconds, 100% in 4 min 9 sec, 100% in 4 min 21 sec
OWT: 93% in 7 min 55 seconds, 90% in 7 min 45 seconds, 95% in 7min 55 sec. (I'm using Vimana on 2.3 seconds per task)
RMS: 4.68 (level 3), 4,42(level 1), 5,28 (level 3)
KRN: 80%, 84%, 72%
VMC: 84%, 89%, 83%
ENS did the CBT once: 79%
TVT/PHY: I'm using easyflightrainig.app (lennarts app) and I usually get above 80% with each run ( A lot of tasks I started to know them by heart) _________________ DLR Certificate: ✓✓✓
LHG Assessment: failed |
fly_away_ Bruchpilot
Anmeldungsdatum: 01.10.2024 Beiträge: 8
Verfasst am: Di Okt 15, 2024 2:46 pm Titel: |
I think your results look pretty good. My results were almost similar and I passed. If you are well rested and relaxed on the day of the test, you will have high chances to pass. Maybe try to improve your speed for SKT, and your accuracy at KRN. Good luck!  |
LH2Y NFFler
Verfasst am: Mi Okt 16, 2024 2:13 pm Titel: |
Thank you for this feedback, may I know have u passed the test if so how did u prepare for PHY/TVT and what is the difference between them? _________________ DLR Certificate: ✓✓✓
Verfasst am: Do Okt 17, 2024 3:00 pm Titel: |
| Yes, I have passed the test. TVT was rather similar to the CBT. I found PHY a bit more theoretical and abstract. But everything was doable. I prepared myself with a German script which you can buy on "Kleinanzeigen". It is called "Physikskript und ?bungen zur Vorbereitung auf den Pilotentest". I think it's important that you have a good overview of all the topics and that you understand the basic physical concepts. By preparing with the script, I even got an A in technical understanding, although I really had to start from scratch in physics. |
LH2Y NFFler
Verfasst am: Fr Okt 18, 2024 3:21 pm Titel: |
Thank you very much!, I have translated the script and I'm reading through it, do you have any other advices especially for MIC? _________________ DLR Certificate: ✓✓✓
LH350 NFFler
Anmeldungsdatum: 20.04.2024 Beiträge: 22 Wohnort: EDDW  |
Verfasst am: Fr Okt 18, 2024 4:34 pm Titel: |
Don't prepare (too much) for MIC, as you might get used to a specific sensitivity that might differ from the one used in the DLR. You have enough time to train while you are there  _________________ DLR-Test ✅
LHG Assessment ✅
EASA Medical Class 1 / FAA Class 3 ✅
--- LHG2408-P --- |
LH2Y NFFler
Verfasst am: Fr Okt 18, 2024 4:48 pm Titel: |
Your signature looks outstanding, having passed all of these assessments must be a thing that you are proud of. thanks or the advice. _________________ DLR Certificate: ✓✓✓
LH350 NFFler
Verfasst am: Fr Okt 18, 2024 5:20 pm Titel: |
You are quite welcome! And thanks for the kind words  _________________ DLR-Test ✅
LHG Assessment ✅
--- LHG2408-P --- |
