flathead Navigator
Anmeldungsdatum: 18.12.2014 Beiträge: 35
Verfasst am: Di Jul 14, 2020 8:03 am Titel: Mittelohroperation (Otosklerose) und Medical |
Hallo
hat jemand von euch bereits eine Mittelohroperation hinter sich? Bei mir besteht der Verdacht auf Otosklerose. Ich habe bereits ein Medical Class 1 und laut Fliegerarzt sollte es auch kein Problem darstellen, sofern dass Gehör nachher wieder den Ansprüchen einer Medical Class 1 Nachuntersuchung entspricht.
Im Part-MED kann ich auch nichts genaues finden was eine Otosklerose angeht... Nur in den UK fand ich diesen Gesetzesauszug:
Stapedectomy (==> wird bei einer Otosklerose durchgeführt)
To ensure full healing, recertification is only allowed a minimum of three months after surgery, subject to a satisfactory specialist report confirming no complications, the absence of dizziness, spontaneous or positional nystagmus and a satisfactory hearing result.
im Part-MED finde ich nur:
AMC1 MED.B.080 Otorhino-laryngology
(a) Hearing
(1) The applicant should understand correctly conversational speech when tested with
each ear at a distance of 2 metres from and with the applicant?s back turned
towards the AME.
(2) The pure tone audiogram should cover the 500 Hz, 1 000 Hz, 2 000 Hz and
3 000 Hz frequency thresholds.
(3) An applicant with hypoacusis should be referred to the licensing authority. A fit
assessment may be considered if a speech discrimination test or functional flight
deck hearing test demonstrates satisfactory hearing ability. A vestibular function
test may be appropriate.
(4) If the hearing requirements can only be met with the use of hearing aids, the
hearing aids should provide optimal hearing function, be well tolerated and suitable
for aviation purposes.
(b) Comprehensive otorhinolaryngological examination
A comprehensive otorhino-laryngological examination should include:
(1) history;
(2) clinical examination including otoscopy, rhinoscopy, and examination of the mouth
and throat;
(3) tympanometry or equivalent;
(4) clinical assessment of the vestibular system.
(c) Ear conditions
(1) An applicant with an active pathological process, acute or chronic, of the internal or
middle ear should be assessed as unfit. A fit assessment may be considered once
the condition has stabilised or there has been a full recovery.
Page 27 of 61
Annex to ED Decision 2011/015/R
Page 28 of 61
(2) An applicant with an unhealed perforation or dysfunction of the tympanic
membranes should be assessed as unfit. An applicant with a single dry perforation
of non-infectious origin and which does not interfere with the normal function of the
ear may be considered for a fit assessment.
Hat irgend jemand von euch Erfahrungen mit einer Otosklerose oder Mittelohroperation?
Besten Dank und Gruß |
