Obama fordert $100-per-flight von der GA
joyflight
Anmeldungsdatum: 13.08.2009
BeitragVerfasst am: Di Jan 17, 2012 8:03 am    Titel: Obama fordert $100-per-flight von der GA Antworten mit Zitat
White House: 'Why we need aviation user fees'
http://www.aopa.org/advocacy/articles/2012/120113white-house-aviation-user-fee-response.html
By Sarah Brown
After almost 9,000 people urged the president to take damaging aviation user fees off the table, the administration on Jan. 13 offered its response: No way.
In a response to a petition on the White House’s “We the People†website, Office of Management and Budget Associate Director for General Government Programs Dana Hyde reaffirmed the Obama administration’s commitment to a proposed $100-per-flight fee for use of air traffic services, claiming that the fee would both “ensure that everyone is paying their fair share†and help reduce the deficit.
“We are disappointed but not surprised that the administration continues to seek a $100 user fee on general aviation flights,†said AOPA President Craig Fuller. “Congress has repeatedly said that a GA user fee is an unacceptable method of funding the air traffic system. Pay at the pump has worked since the dawn of powered flight and it still works. The last thing we need right now is to create an expensive new bureaucracy to fix what isn't broken.â€
AOPA member Kevin Mossey of Marion, Iowa, started the petition Sept. 23 in response to a White House deficit-reduction proposal that would impose a $100-per-flight fee for flights in controlled airspace. The petition pointed out that the existing system of revenue generation, collected through excise taxes, allows more of the revenue collected to go toward the operation of the air traffic control system. It also explained that fuel taxes more accurately reflect the amount of ATC services, “as a flight from NYC to LA will require more controller time than a flight from NYC to Boston.†The petition gained 8,904 signatures—well more than the threshold at the time for earning a response from the White House.
In the response, Hyde said the administration wanted to make sure that those who benefit from the airspace system share the costs equitably.
“For example, under current law, a large commercial aircraft flying from Los Angeles to San Francisco pays between twenty-one and thirty-three times the fuel taxes paid by a corporate jet flying the same route and using the same FAA air traffic services,†according to the response.
Really? Paying the 21.9-cents-per-gallon tax on noncommercial jet fuel, operators of a Gulfstream IV business jet would pay about $87 in fuel taxes. The commercial jet fuel tax is 4.4 cents per gallon; even with a much higher fuel burn, operators of an Airbus A320 would pay about $68 in fuel taxes. AOPA maintains that GA is willing to pay its fair share into the system—but payment shouldn’t be based on faulty calculations.
A loose grasp on the workings of the aviation system also revealed itself in the ambiguous language of the proposal: It would exempt flights outside of “controlled airspace,†but doesn’t define the term. (Is Class E “controlled�) The original proposal also would exempt “recreational piston aircraft,†a nebulous distinction. The response to the petition refers instead to exempting “all piston aircraft,†among other categories—but no segment of aviation can count itself immune once the bureaucratic structure for user fees is introduced. User fees bypass congressional budgeting processes and can be raised or expanded at will. AOPA holds that GA should pay its share using the time-tested funding system that has supported the National Airspace System for years.
Alice D.
Anmeldungsdatum: 16.02.2011
BeitragVerfasst am: Di Jan 17, 2012 10:09 am    Titel: Antworten mit Zitat
Ich checks nicht. Was gilt denn als "Air traffic service"? Die normale Radarüberwachung für VFR-Flieger? $100? Dann kann ich ja gleich in DE fliegen...
joyflight
BeitragVerfasst am: Di Jan 17, 2012 10:45 am    Titel: Antworten mit Zitat
ATS fee ist frei übersetzt einfach sowas wie luftsteuern. (in deutschland z b luftverkehrssteuern - nicht zusammenhängend aber genauso sinnlos)
zumal sie noch unschlüssig sind, ob luftraum Echo betroffen ist oder nicht.
Zuletzt bearbeitet von joyflight am Di Jan 17, 2012 12:55 pm, insgesamt einmal bearbeitet
Alice D.
BeitragVerfasst am: Di Jan 17, 2012 11:04 am    Titel: Antworten mit Zitat
Naja, wenn der normale Cessnaflieger dann nicht mal in eine Kontrollzone fliegen darf ohne seine Geldbörse auszukippen... da wird den Leuten doch beigebracht nur irgendwo auf dem Land rumzugurken. Und wenn es mal drauf ankommt in eine Kontrollzone zu fliegen, können sie es nicht.
Elmar
Anmeldungsdatum: 18.05.2007
BeitragVerfasst am: Di Jan 17, 2012 1:19 pm    Titel: Antworten mit Zitat
Hmm ... mir kommt es so vor, als ob es nun langsam in "Mode" kommt, die GA als Steuerquelle anzustechen, um die Haushalte zu konsolidieren (Italien, USA, wer mag folgen?).
Alles Gute!
Elmar
Altitude, Airspeed, Brain - You need two of them to survive.
joyflight
BeitragVerfasst am: Di Jan 17, 2012 3:14 pm    Titel: Antworten mit Zitat
österreich hast wohl "vergessen"?
in dem land braucht man sogar einen steurbevollmächtigten.
easa hat auch im allgemeinen was gegen's (AL) fliegen, anscheinend
EDML
Anmeldungsdatum: 19.09.2007
BeitragVerfasst am: Di Jan 17, 2012 9:31 pm    Titel: Antworten mit Zitat
Na ja, es soll aber nur Turbinenflugzeuge betreffen.
Wenn man sich die Betriebskosten z.B. einer King Air ansieht dann ist das im Vergleich nicht die Welt.
IFR bezahlt hier in D ja auch schon Anfluggebühren. Über 2t sind Airwaygebühren fällig - da ist man schneller bei mehr als $100.
Gruß, Marcus
joyflight
BeitragVerfasst am: Di Jan 17, 2012 10:00 pm    Titel: Antworten mit Zitat
ob es gut ausgeht oder nicht, hängt aber nicht vom "parlamentarischen willen ab"
wie gesagt, bis zu recreational (also ungefähr ultraleichtt) und "luftraum echo" war das geplant - das hatte am anfang also nichts mit airways und turbinen zu tun.
allerdings ist die aopa drüben mit mehreren lobby programmen u a vertreten durch travolta, henry ford, etc. ein bisschen weniger eine lusche als unsere "vertreter" diesseits des teichs.
Luftkoenig
BeitragVerfasst am: Fr Jan 20, 2012 3:25 pm    Titel: Antworten mit Zitat
ATS = Air Traffic Services...Gebühr.
Es geht um IFR fliegen. VFR wäre exempted.
Somit in etwa wie bei uns mit Eurocontrol. Allerdings wäre ich saufroh, nur 100 USD pro Flug zu latzen.
Nachdem die Kolben wohl nicht belastet werden sollen, ist fast komplett D-E/D-G (wie bei uns) und D-I frei.
Bei ner KingAir wären 100 Bucks pro Flug nicht wirklich die Welt. Für ne 152 sähe das natürlich annersch aus...
joyflight
BeitragVerfasst am: Fr Jan 20, 2012 4:09 pm    Titel: Antworten mit Zitat
Luftkoenig hat folgendes geschrieben:
...Es geht um IFR fliegen. VFR wäre exempted....
wo hast du das her?
Luftkoenig
BeitragVerfasst am: Fr Jan 20, 2012 7:29 pm    Titel: Antworten mit Zitat
Gelesen, weiss aber nicht mehr genau wo. Es geistern aber einige Versionen durchs Netz.
Die AOPA schreibt: The latest is a White House proposal to charge a $100 fee on many flights in controlled airspace or that involve the use of ATC services.
Controlled Airspace und use of ATC services wäre wohl eher IFR, würde ich jetzt mal so sagen. Less Kontrollzonen.
joyflight
BeitragVerfasst am: Sa Jan 21, 2012 8:18 pm    Titel: Antworten mit Zitat
so hat sich das auch angehört, wie eine persönliche vermutung.
echo hat aber services, egal ob sie dir gefallen oder nicht. die bereitstellung hängt weniger davon ab ob du explizit erwähnst "request follow me", denn die qualität des luftraums muss die verfübarkeit garantieren (sogar für VFR), das kann nicht funktionieren wenn's heisst "heute hat mal keiner nach unterstützung verlangt, also machen wir zu" (und nehmen auch keine gebühren). keine ahnung wie's drüben ist, aber hierzulande ist der FIS, der kleine bruder vom radar, sogar eine extra person, nur um die vfr betreuung ganz sicher sicherzustellen (den fis mann als nicht-ATC einzustufen wäre sehr spitzfindig und nicht ganz korrekt)
nichtdestotrotz bleibt alles spekulation und scheint bei weitem noch nicht (fertig) ausgefochten.
tatsache ist, es wurde eine maxime geplant, und auf druck des widerstandes müssen die ausnahmen mehr und mehr konkretisiert (und ausgeweitet) werden - das hat aber nichts mit einer ursprünglich laschen forderung zu tun.
